Date/Time: Tue, 04 Feb 2025 18:39:20 +0000
copying settings to a new Sierra copy
View Count: 1197
[2020-02-08 01:49:47] |
arruga - Posts: 253 |
Hi I got a second copy of Sierra installed on a VPS.\ Is it possible o transfer ALL, symbol settings, gral trade settings, chart settings, tool bars, etc from one sierra copy to the other? thanks |
[2020-02-08 02:41:26] |
sourdubber - Posts: 52 |
I am not sure this will work but in the File menu, there is a "Send file to user" option. Enter your username in the field and choose files you want to transfer after clicking on the "Select file" button. Basically, you're sending those files to yourself. Let me know how it goes because I plan to migrate to VPS in the near future as well.
[2020-02-08 04:49:07] |
Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
