Date/Time: Sun, 19 May 2024 00:52:45 +0000
need to trial SC to use with two brokers AMP and IB
View Count: 659
[2020-02-07 22:27:42] |
User475862 - Posts: 31 |
I downloaded the rial version but the IB connection is not working. What do I need to do to be able to have two coneections one to AMP and one TO Ib for trade both account. Thanks |
[2020-02-08 04:50:32] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". ----- Follow the setup instructions here: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-09 23:34:36] |
Hi Thanks . the to date in the charts and DOM is 2020-01-28. not sure how to get it to be the correct date? |
to date.PNG / V - Attached On 2020-02-09 23:33:28 UTC - Size: 48.13 KB - 212 views |
[2020-02-09 23:54:15] |
Notice that you are using a year 2021 symbol in that chart.
[2020-02-10 03:31:00] |
duh!!! sorry about that :) so can I have one sierra package 5 and run on one computer: 1 AMP account + 1 IB Account and another 1 IB account on another computer? Data feed will be from AMP. Thanks |
[2020-02-10 10:07:44] |
Yes. They can also be on the same computer.
