Date/Time: Sat, 18 May 2024 23:29:44 +0000
FX Continous Futures Data
View Count: 517
[2020-02-07 16:03:15] |
User623717 - Posts: 3 |
I am interested to better understand how to obtain continuous FX futures data. Is this possible from any of the current feeds ?
[2020-02-07 18:36:39] |
Yes. Use this service: Sierra Chart Historical Data Service And then use this feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-10 07:23:07] |
Thank you. Worked fine. Are you able to comment on the data itself? Does it show all bid/ask quoted at the tile, or all actual trades, with time and date stamp or where can I find information on this? Thank you. |
[2020-02-10 09:48:33] |
or all actual trades, with time and date stamp Yes this is the case.
