Date/Time: Tue, 04 Feb 2025 18:47:40 +0000
Developer
View Count: 1335
[2020-02-07 15:46:09] |
User170575 - Posts: 221 |
Hi--since the TD feed is toast---would a look at Etrade be of any interest---they have an SDK in several languages----it's above my paygrade but would be happy to get the SDK for you? Or maybe you have a developer I could work with? Have a nice weekend! Cy https://www.programmableweb.com/api/etrade/sdks |
[2020-02-07 21:33:24] |
We are looking at adding support for TD Ameritrade again using their new API. Refer to: Stock Trading Plans ( Question for our Interactive Brokers Users) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
