Date/Time: Sun, 19 May 2024 01:41:47 +0000
SC shows double the size traded in the activity log (only today) AMP + CQG
View Count: 496
[2020-02-07 15:43:07] |
User46930 - Posts: 28 |
Today I have traded my common setup 5 MNQ and 1 CL contract For some reason trade activity log shows 10 contracts and 2 contract respectively but 'closed quantity' shows correct size 5 MNQ & 1 CL You can see the screenshot attached There was a short connection drop at about 8.45 US CT so this might be the reason? |
2020-02-07_16-38-23.png / V - Attached On 2020-02-07 15:42:54 UTC - Size: 170.32 KB - 223 views |
[2020-02-07 16:09:17] |
trade activity log attached too
Date Time Of Last Edit: 2020-02-07 16:11:03
Private File |
[2020-02-10 02:31:50] |
Sierra_Chart Engineering - Posts: 14423 |
There are probably duplicate fills. You can delete the duplicates through the Trade Activity Log: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Update to the current version of Sierra Chart: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
