Date/Time: Wed, 30 Sep 2026 12:51:21 +0000
moving average
View Count: 1150
| [2020-02-07 14:28:18] |
| samson gluck - Posts: 6 |
what is a moving average of this? ergodic inupt data last moving averaga exponential long 5 short 35 multiplier 1 signal line 5 |
Private File |
| [2020-02-08 04:41:57] |
| Sierra_Chart Engineering - Posts: 25009 |
We are not sure exactly what your question is, but you will find the explanation for all of the Inputs to the Ergodic study along with the calculations here: Ergodic Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-02-09 15:40:16] |
thank you for replying my question is not how it's calculated the ergodic my question is how to set it up I will send you a picture exactly what I want in the picture I send you you will see they have a second line what's calculate automatically calling the average you should check it you have a second line beside their ergodic and because sierra didn't have it automatically my question is how to se up just send me what's number to put in the length when I set up another moving average in the bottom please look at the picture you will see you settings in the settings from ensign I try to compare |
Private File |
| [2020-02-09 22:35:01] |
i post again because I want to make very clearly the question is very simple I want to add a second line- moving average based in the ergodic so my question is what is the average of this calculation=what's number to put in the length when I set up another moving average in the bottom ergodic inupt data last moving averaga exponential long 5 short 35 multiplier 1 signal line 5 |
| [2020-02-10 02:59:50] |
We require a paid account for further support.
| [2020-02-10 03:20:14] |
i have account with transact Username mg8453622127 and i paid 19.99 I need a little help and for you are a very easy thing, please make time to call me |
| [2020-02-10 18:36:41] |
Ok we see, but understand that 19.99 is not paid to us. We will look over what you have written and create a study collection for you and if we have more questions we will get back to you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-10 18:36:58
| [2020-02-10 18:57:45] |
| John - SC Support - Posts: 48062 |
You have two choices in terms of adding a Moving Average to the Ergodic line. The first is to set the Draw Style for the Erg Signal Line in the Ergodic Study to Line. This will display the Moving Average of the Ergodic Line using the MovAvg Type and the Signal Line MovAvg Length. The only downside to using this option is that the Moving Average Type that has been selected for the Ergodic is the same one used for the Moving Average. Refer to the information here on setting the Draw Style for a Subgraph: Chart Studies: Subgraphs Tab >> Draw Style The other option would be to add a separate Moving Average study to the chart which is based on the Ergodic study. The advantage to this is that you can select a different type of Moving Average. We have attached a Study Collection to this thread that contains 2 Ergodic Studies, one that has the Erg Signal Line turned on giving you the Moving Average based on the selected MovAvg Type in the Ergodic study. The other Ergodic Study also has a separate Simple Moving Average that is drawn in the same region. Refer to the information here for how to use a Study Collection: Study Collections: Using a Study Collection Provided by Sierra Chart Support As to what Moving Average and what Length to use, those are personal choices. Just try different values until you find one that works for what you are looking for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
