Date/Time: Tue, 04 Feb 2025 19:59:42 +0000
Dual Y Axis Values
View Count: 808
[2020-02-06 20:15:08] |
User184576 - Posts: 20 |
Hi, Is there a way to display price data on one Y axis and percentage data on the other Y axis? Any assistance would be appreciated. Thanks! |
[2020-02-06 23:53:06] |
If you have information being displayed in the same region with Price Data and Percentage data, then you would turn on the Left Side Scale to have both scale types. Refer to the information here: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
