Date/Time: Thu, 02 May 2024 05:59:27 +0000
VPS Monitoring/Uptime Monitoring
View Count: 807
[2020-02-06 17:54:06] |
macrohedged - Posts: 6 |
We have 10-15 instances running SC and automated trading sits on this. Does SC have any alerting that can be sent via email if the following happens DTS drops App crashes Error on the trader service log? |
[2020-02-06 18:45:33] |
Are you running 10 to 15 instances of Sierra Chart on a VPS? You really should be using a dedicated server for this. Sierra Chart should not crash so long as you are not running any custom studies. If there is any loss connection to the external service you can get an email notification. Refer to: General Settings Window: Server Connection Lost Alert (Global Settings >> General Settings >> Alerts >> Other Alerts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-06 18:46:46
