Date/Time: Thu, 02 May 2024 02:40:39 +0000
Connect to data feed
View Count: 453
[2020-02-06 15:36:53] |
User609830 - Posts: 3 |
Hello, I cannot to connect to CQG Data Feed via Sierra chart. Could you help me with this. Kind regards, Mariusz
[2020-02-06 17:56:59] |
You need to change to the CQG Web API connection instead of the FIX connection. This is described here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2000 The easiest thing to do is to update Sierra Chart to the current version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-06 17:57:34
