Date/Time: Mon, 25 Nov 2024 01:40:43 +0000
New to SC - Need data feed for both Equities (TD Ameritrade) and for Futures (TransAct)
View Count: 1239
[2014-01-05 23:44:19] |
User53494 - Posts: 1 |
I am new to this software. I have both an Infinity Futures and TD Ameritrade accounts. I would like to use SC for my charting sotware but need to know: 1. How do I set up BOTH data feeds and 2. What Package would I have to sign up for and 3. How many terminals can I use for this setup? Thank you in advance. Look forward to having SC in my toolbox for a long time! |
[2014-01-06 18:53:56] |
1. Refer to this page: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html 2. You will need Sierra Chart package 1, 3 or 5. Most users use package 3, but package 1 may be fine for you as well. You can find out about the packages here: http://www.sierrachart.com/index.php?l=doc/Packages.php 3. Please refer to the section here: http://www.sierrachart.com/index.php?l=doc/PurchaseInformation.php#Licensing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
