Date/Time: Tue, 04 Feb 2025 18:32:17 +0000
Bug in 2045
View Count: 609
[2020-02-06 04:53:21] |
nicktrader - Posts: 734 |
I use the study "symbol..." in every TF. Each TF has a different color. After uploading 2045 I get this picture. For example, if I move a text in M1, the texts in M3, M15 etc. move automatically, as if all texts were connected. Then I changed back to 2040 and everything is fine. |
Study Symbol.png / V - Attached On 2020-02-06 04:52:03 UTC - Size: 203.12 KB - 242 views |
[2020-02-06 18:24:57] |
Provide that chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-07 02:53:51] |
pls see attached file
Attachment Deleted. Private File |
[2020-02-08 04:38:36] |
Sierra_Chart Engineering - Posts: 18246 |
We did not yet examine the Chartbook but if the problem is related to what we think it is, it is resolved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-08 04:38:51
[2020-02-08 05:12:15] |
Resolved with 2048. Txs
