Date/Time: Thu, 02 May 2024 08:19:55 +0000
Reset P&L each day
View Count: 758
[2020-02-06 00:43:00] |
User718585 - Posts: 32 |
How come the P&L on my trade window does not reset back to zero each day and how can I make it reset? Thanks |
[2020-02-06 13:09:20] |
Any word on this?
[2020-02-06 17:39:34] |
Update to the latest Pre-Release (v 2045) in which this has been resolved. The What is New notes also explain this. Use the Fast Update option as documented here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
