Date/Time: Thu, 02 May 2024 09:00:34 +0000
Acceleration Indicator
View Count: 811
[2020-02-05 17:34:27] |
User827002 - Posts: 28 |
I'm looking for an indicator that measures acceleration in the market. The formula would take into consideration how many ticks price has moved in a given period of time, relative to the average movement in ticks for each minute of trading. (i.e: in the past half hour, we’ve moved 1500 ticks, which averages to 50 ticks for every minute of trading) This average would be given a divisor so that it always equals 1. (so, in this case, it would be divided by 50 because that is the average movement per minute in the past 30 minutes) So if price then moves 70 ticks in a minute, the indicator’s value would show 1.4. Does this type of indicator exist?
[2020-02-05 18:50:19] |
Sierra_Chart Engineering - Posts: 14173 |
This would be something that you would need to custom create.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-05 18:50:28
