Date/Time: Sat, 18 May 2024 06:48:07 +0000
custom study - mac/parralels
View Count: 479
[2020-02-04 18:47:34] |
JDP6 - Posts: 9 |
i am trying to upload a custom study in sierra 64 bit. i am running parralels on mac when i try to laod the study, i get the following error - error loading; windows error code 126. the specified module could not be found, likely missing dependency file. please advise. thanks, |
[2020-02-04 18:50:54] |
You need to contact the developer of the custom study about this and tell them you are getting that error message.
