Date/Time: Mon, 25 Nov 2024 02:34:08 +0000
New installation SC
View Count: 1083
[2014-01-05 19:45:29] |
AKR - Posts: 523 |
Hello, am about to completely install my PC new. In which folders/files does SC save the various settings I have done? General Settings, Graphics Settings especially? Will I be abel to restore SC as it is right now? Thx & rgrds |
[2014-01-05 20:13:51] |
Refer to help topic 15: Http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
