Date/Time: Sat, 18 May 2024 03:51:59 +0000
Rithmic Data
View Count: 1482
[2020-02-04 11:30:33] |
User246937 - Posts: 3 |
i am having trouble getting live data with my rithmic set up. Please help me connect.
[2020-02-04 18:48:28] |
We see you have been using the Denali Exchange Data Feed but it did not renew probably because of an insufficient balance. Add sufficient credit here: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit And then you can reactivate the service from here: https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices Also be aware we have discontinued technical support for Rithmic and recommend this service instead: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-04 18:49:06
