Date/Time: Sat, 18 May 2024 07:13:40 +0000
New Account Sign-up
View Count: 745
[2020-02-03 22:05:46] |
rizome - Posts: 1 |
Hi, I am looking to sign up to a new account, but I am finding it quite difficult to understand what steps I need to take in order to get to the correct configuration and pricing, for what I need: I would like to use Seirra Charting for Charting and Real-time data feed for EUREX products only (no requirement for hooking up to Order Routing), such as the 10 Year German Bund. Can you please advise what I would need to do in order to purchase just Reat-time Charting Package for EUREX based products. The account setup only refers to Dinali, is Dinali only required for FX Products on CME etc, does the base package by default include Sierra Real Time Data Feeds and if so would it already include EUREX reat-time data feed, hence would I only have to then pay the EUREX Exchange Fee on top, which comes to a total of $36 per month? Many Thanks. Jaz |
[2020-02-04 19:03:17] |
The Real-Time data feeds are a separate price and are not automatically included with any of the Sierra Chart packages. Just so you are aware, there is Delayed Streaming data for the CME Group that comes with the Advanced Service package 5 of Sierra Chart. You can find out more information on this here: Delayed Exchange Data Feed In your case, since you want Eurex data, you would need the Sierra Chart Exchange Data Feed for your Real-Time data. Follow the Setup Instructions here: Sierra Chart Exchange Data Feed: Setup Instructions On the same page for the Sierra Chart Exchange Data Feed Setup Instructions, you will also find the pricing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
