Date/Time: Mon, 25 Nov 2024 02:33:10 +0000
GDI exception with 1071
View Count: 1633
[2014-01-05 17:08:14]
cmb999 - Posts: 211
Hello, I just upgraded to 1071 from 1046, using mtGox trading connection:
now getting,
Software version: 1071 | 2014-01-05 12:09:51
Usage end date: 2014-12-16 | 2014-01-05 12:09:51
Enabled for: Sierra Chart Historical Data Service. | 2014-01-05 12:09:51
Received 0 data feed usernames. | 2014-01-05 12:09:51
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-01-05 12:09:51
Active service: MtGox Trading | 2014-01-05 12:09:51
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-01-05 12:09:51
2014-01-05 12:09:51 Local computer clock time | 2014-01-05 12:09:51
2014-01-05 17:09:51 GMT time | 2014-01-05 12:09:51
2014-01-05 12:09:51 Time zone adjusted time | 2014-01-05 12:09:51
Time difference to server time: 0 seconds. | 2014-01-05 12:09:51
Program path: C:\SierraChart\ | 2014-01-05 12:09:51
Data Files path: C:\SierraChart\Data\ | 2014-01-05 12:09:51
OS Version Number: 5.2 | 2014-01-05 12:09:51
Checking for new symbol settings for scmtgt | 2014-01-05 12:09:51
MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2014-01-05 12:09:56
Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 443 | 2014-01-05 12:09:56
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-01-05 12:09:56
The network socket is connected. | 2014-01-05 12:09:56
Bitcoin Data (MtGox): Connected to server. | 2014-01-05 12:09:56
Bitcoin Data (MtGox): Sending logon request message. | 2014-01-05 12:09:56
Bitcoin Data (MtGox) Server Info - Server Name: . Server Version: . Provider Name: . | 2014-01-05 12:09:56
Bitcoin Data (MtGox) - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-01-05 12:09:56
Bitcoin Data (MtGox) - Successfully connected. | 2014-01-05 12:09:56
Get Wallet History not done because request is already outstanding | 2014-01-05 12:10:02
MtGox Trading - Starting real-time market data updates for: BTCUSD | 2014-01-05 12:10:05
HD Request # 2 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2014-01-05 12:10:05
HD Request # 2 - Download start Date-Time: 2014-01-05 12:09:04.0 | 2014-01-05 12:10:05
HD Request # 2 - Using server: btc.sierracharts.com port 10149 | 2014-01-05 12:10:05
An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-01-05 12:10:05
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-26 07:00:00. Next Bar Date Time: 2013-11-26 06:00:00. Filename: C:\SierraChart\Data\BTCUSD.scid | 2014-01-05 12:10:05
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 07:00:00. Next Bar Date Time: 2013-12-11 06:00:00. Filename: C:\SierraChart\Data\BTCUSD.scid | 2014-01-05 12:10:05
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 07:00:00. Next Bar Date Time: 2013-12-12 06:00:00. Filename: C:\SierraChart\Data\BTCUSD.scid | 2014-01-05 12:10:05
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-01-05 12:10:06
The network socket is connected. | 2014-01-05 12:10:06
HD Request # 2 - Sending historical data logon request message. | 2014-01-05 12:10:06
HD Request # 2 - Requesting up to 500 days of Intraday data. Record interval: 60 | 2014-01-05 12:10:06
An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-01-05 12:10:06
HD Request # 2 - Decompressing data. | 2014-01-05 12:10:06
HD Request # 2 - Receiving Intraday data for BTCUSD starting at 2014-01-05 12:09:04 | 2014-01-05 12:10:06
HD Request # 2 - Timestamp of first Intraday data file record written: 2014-01-05 12:09:04 | 2014-01-05 12:10:06
The network socket for historical data has been closed. | 2014-01-05 12:10:06
HD Request # 2 - Received 2 records from 2014-01-05 12:09:04 to 2014-01-05 12:10:00 (56.0 seconds) and wrote 2 records for BTCUSD | 2014-01-05 12:10:06
HD Request # 2 - Intraday download COMPLETE for BTCUSD | 2014-01-05 12:10:07
Real-time Intraday chart data file updates started for BTCUSD | 2014-01-05 12:10:07
An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-01-05 12:10:07
An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-01-05 12:10:08
An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-01-05 12:10:09
An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-01-05 12:10:10
An unhandled exception was caught in c_Chart::WindowProc. Message: 275, wParam: 100, lParam: 0 | 2014-01-05 12:10:11
Date Time Of Last Edit: 2014-01-05 17:10:49
[2014-01-05 18:55:29]
We are looking into this. Why do you refer to this as a "GDI exception"?
[2014-01-05 19:10:31]
cmb999 - Posts: 211
hello, was referencing earlier thread,
https://www.sierrachart.com/supportboard/showthread.php?t=39789
not necessarily accurate description
thanks,
Date Time Of Last Edit: 2014-01-05 19:11:12
[2014-01-05 19:19:54]
We cannot duplicate the problem. We need to get one of your Chartbooks to test with. Attach it here following these instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile
Only attach one Chartbook please.
[2014-01-05 19:49:33]
cmb999 - Posts: 211
attached,
Date Time Of Last Edit: 2014-01-05 19:49:59
Private File
[2014-01-05 20:10:47]
Thank you. We have found the problem and we will be releasing 1072 in about 10 minutes.
