Date/Time: Mon, 25 Nov 2024 02:44:22 +0000
Chart drawing type
View Count: 1306
[2014-01-05 17:01:30] |
user54342 - Posts: 42 |
Hi How do I change chart drawing type on OHLC when I open new chart? Because when I open symbol it shows me in candelstick so I have to change it on OHLC everytime. Where can I change primary type on OHLC? Thank you Julius |
[2014-01-05 21:34:23] |
This is explained here in help topic 20.3: http://www.sierrachart.com/index.php?l=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-05 23:01:38] |
Thank you I have one more question. It is not connected with this topic. Do connection with Mirus Futures(Zen-Fire) works? Can I connect to their data feed? Thank you Julius |
[2014-01-05 23:07:17] |
No. Zen-Fire is not supported anymore because of interface changes they have made to their system. And at the present time you would not want to use it anyway because their backend trading system is having significant problems at the present time which they have acknowledged.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-05 23:08:14
[2014-01-05 23:33:45] |
I understand. And what is connected with switching to CTS T4? What will be my data provider? What will be my fees for that data? Will I use your data, my broker(Mirus) data or my clearing firm(Dorman) data? How myuch I will have to pay for that data? Thank you Julius |
[2014-01-06 00:25:33] |
CTS T4 is one of many of the supported trading platform services that Sierra Chart supports. You can find them all on this page: http://www.sierrachart.com/index.php?l=doc/data.php It is supported by Dorman. So some Zen-Fire users are using it. The CTS T4 system provides its own market data. There probably is a 25 USD a month charge for it, but you really need to ask your broker about this. You can optionally use the Sierra Chart market data feed with it. More information about this here: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
