Date/Time: Sat, 18 May 2024 07:13:50 +0000
[User Discussion] - Trading System Based on Alert Condition
View Count: 439
[2020-02-03 19:12:43] |
User190501 - Posts: 92 |
Hi Support. Kindly send me the few code lines to update the subject study such that: Entry order can be a stop order or a stop limit order instead of a market order with the ability to set the entry price above/below the high/low of the alert bar. Add a stop loss for that order at x ticks below the low or above the high of the alert bar. For example: Alert is for a buy order. So user selects the buy stop order Stop order entry level : X ticks above the high of alert bar. Stop loss : -X ticks below the low of the alert bar. If not filled and new alert is true, cancel the past buy stop orders, etc. I know this would be done by few code lines changes in the NewOrder section, and would appreciate if you can provide these updates... Thanks a lot in advance for your help. |
[2020-02-04 18:07:15] |
Kindly inform how to modify the study for such requests.
