Date/Time: Sat, 18 May 2024 06:22:32 +0000
ampfutures account 123436
View Count: 588
[2020-02-03 17:16:58] |
User909555 - Posts: 1 |
Hello, My live account from ampfutures with the cqg data are activated with the sierrachart package 5. So now how connect the sierrachart plateform to my ampfutures ? Eddy |
[2020-02-03 19:41:44] |
Your Sierra Chart account is expired. Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access So you need to pay for usage time. After that follow the CQG set up instructions on this page: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
