Date/Time: Sat, 18 May 2024 05:59:29 +0000
Continuous contracts
View Count: 496
[2020-02-03 13:04:26] |
User255315 - Posts: 128 |
Hi SC, I am experimenting with continuous contracts and have set a custom rule for the rollover condition(based on date/days before the month of the contract). However when i do select the date-based rollover from the dropdown of the symbol chart, it is still using thew old rule to calculate the rollover and not the new custom rule. How do i enable the custom rule for rollover for any symbol chart? Date Time Of Last Edit: 2020-02-03 13:31:02
[2020-02-03 22:04:30] |
Sierra_Chart Engineering - Posts: 14423 |
Follow the instructions here: Global Symbol Settings: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
