Date/Time: Sat, 18 May 2024 04:37:22 +0000
Custom Calculated Symbol TradeDOM
View Count: 463
[2020-02-03 11:09:26] |
User255315 - Posts: 128 |
Hi SC, I saw your post about the support for custom calculated symbols providing historical support now and that is fantastic news. I have a few doubts regarding custom calculated symbols since the documentation on them is limited. 1. Can we open trading dom for the custom calculated symbols, and most importantly, if we place orders on this DOM prices, does sierra manage the respective fills on the constituent spreads/symbols. 2. Is there any way to define a custom calculated symbol through ACSIL. If not is it possible for you to add fields that might enable us to create and define the several fields required, through ACSIL? |
[2020-02-03 19:42:54] |
1. Yes you can open a Trading DOM for a custom symbol. But trading is not yet supported. This will come later in the year. 2. No. We do not expect this would be added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-03 19:43:12
