Date/Time: Sat, 18 May 2024 09:05:28 +0000
Trade activity log update while Sierra is closed
View Count: 437
[2020-02-03 08:28:20] |
User28706 - Posts: 22 |
Hi, I closed my Sierra connection and placed trades from my Rithmic Pro platform. When I reopened Sierra, the above trades did not appear in the trade activity log. So Sierra only recognizes trades while it's opened. Is there a solution so that ALL trades will appear in the log? |
[2020-02-03 09:29:47] |
There is no guarantee that Sierra Chart will be able to get those order fills from the Rithmic system. The solution to this problem is to use this service which maintains long-term and reliable order fill history: Sierra Chart / Trading Technologies Futures Order Routing Service And additionally, all installed instances of Sierra Chart will be able to access this long-term order fill history. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-03 09:30:50
