Date/Time: Sat, 18 May 2024 09:26:57 +0000
How fast can SC process streaming data?
View Count: 516
[2020-02-03 03:03:51] |
User442651 - Posts: 25 |
From the documentation, a study function is called at each Chart Update Interval, whenever an update has been flagged. It appears that the update interval can be as small as 1 millisecond, but can SC really work at that speed? In other words, can I use SC for a trading system that should react within 1 millisecond to some input from the market? |
[2020-02-03 09:17:38] |
The minimum update interval is more like about 10-15 milliseconds. If you need 1ms reaction, you need to use this interface: Automated Trading Management: Low Latency Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
