Date/Time: Sun, 27 Sep 2026 01:38:56 +0000
Clock Positioning Bug?
View Count: 1102
[2020-02-02 23:29:00]
MikeVon - Posts: 20
Hi, when setting up the clock it will not move when I change the position settings after having applied a position change once.
[2020-02-03 09:34:35]
Refer to the documentation for those Input settings:
Clock - RealTime
[2020-02-03 10:58:49]
MikeVon - Posts: 20
The problem is that I cannot change the position of the clock after having changed it once. It is stuck there and will not move regardless of what position coordinates I type in.
The only solution for me is to remove the study and re- add it.
I just wanted to let you know that this is perhaps not working as intended.
[2020-02-03 17:33:39]
The documentation specifically describes this for those Inputs and what you need to do.
[2020-02-03 17:58:17]
MikeVon - Posts: 20
Ok, I downloaded the last version but I still cannot move the clock.
I read the documentation 10 times but cannot find where it says that after you have inputted the coordinates, the clock will never move again unless you delete the study and then reapply it.
Either I am too stupid to understand what is going on, or we are not understanding each other.
Do you understand that despite changing the coordinates of the clock in the settings It does not move around on my chart?
Is that the way it is supposed to be?
Date Time Of Last Edit: 2020-02-03 17:58:57
[2020-02-03 18:51:37]
User196369 - Posts: 41
Yeah it's kind of funky the way it works
"clock will never move again unless you delete the study and then reapply it."
correct
you change the coordinates of the clock instance on your chart by dragging it around the chart or right clicking and setting the anchors. It's basically just another drawing object
[2020-02-03 19:03:31]
MikeVon - Posts: 20
Hi thanks for pointing me in the right direction. I was able to move it after clicking it on the chart.
Thanks so much for your help!
