Date/Time: Sat, 18 May 2024 06:01:27 +0000
[Programming Help] - One bug far from my study running / ACSIL
View Count: 507
[2020-02-02 22:26:33] |
User275592 - Posts: 97 |
Hi, I'm a newbie in ACSIL programming. With the help of support and reading acsil examples, i'm in progress of developping my first study. My study is ok when i do calculation on variables set "by hand" But I still have a problem when trying to read/write data from/to the subgraph. Each subgraph has only one data for calculation. I can see the correct value in the Chart Values window, the compilation is ok ... but ... Could you send me a very simple example of reading / writing to a subgraph ? Thank you very much for your help |
[2020-02-03 10:06:45] |
This is explained here: Working with ACSIL Arrays and Understanding Looping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-03 15:35:58] |
Sorry, but still confused :-( I'm looping reading the web page and i can't understand I just want to store the result of my calculation and then read it Thank you for your help |
