Date/Time: Sat, 18 May 2024 06:48:07 +0000
Market Profile Chart - Can't change volume bar font size
View Count: 919
[2020-02-02 20:08:09] |
User467311 - Posts: 7 |
I build a Market Profile chart and have been able to adjust colors, sizes, and other elements however my volume profile bars are displaying a large font and I am unable to change the size. Under my studies settings I can locate the line that should allow me to change the font size, but changing it has no affect. I have attached a screen shot showing the chart. As can be seen, I am able to adjust the font size of the TPO fonts but not the volume percentage font. Any ideas would be greatly appreciated. http://www.sierrachart.com/image.php?Image=1580674049254.png |
[2020-02-03 19:23:15] |
Sierra_Chart Engineering - Posts: 14423 |
That particular font size is controlled through this particular Subgraph. Refer to the information here: Volume By Price Study: Volume Numbers Text Color and Size (SG7) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-03 19:23:56
