Date/Time: Sat, 18 May 2024 08:16:33 +0000
Numbers Bars
View Count: 496
[2020-02-02 17:53:00] |
User575872 - Posts: 59 |
Hello, I do not know exactly what the coloring in the study "Numbers Bars" of these values means (with the arrow). Can someone help me there?
Sierrachart_02_LI.jpg / V - Attached On 2020-02-02 17:52:13 UTC - Size: 1.7 MB - 213 views |
[2020-02-03 16:17:05] |
It's hard to say exactly, as there are a lot of options, but the simplest explanation is the following settings: - Text Coloring: Based on Dominant Side AskVol BidVol Pecentage - Range 0 Up/Down Color: Black - Range 1 Up/Down Color: Black - Range 2 Up/Down Color: Black - Percent Compare Threshold: 0, 0, 3 This gives a coloring only for those values where one side is more than 300% of the other side. Otherwise, the text is just colored black, which makes them indistinguishable from not being colored at all. Refer to the following for this text coloring method: Numbers Bars: Text Coloring Based on Dominant Side AskVol BidVol Percentage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
