Date/Time: Sat, 18 May 2024 11:28:24 +0000
[Programming Help] - SMA Difference Oscillator
View Count: 632
[2020-02-02 11:40:49] |
MikeVon - Posts: 20 |
I'm trying to find a way to plot the difference between 5SMA and 1SMA as an oscillator histogram. This should show all closes above the 5SMA as positive value bars above a zero line and all closes below the 5SMA as a negative value bar below the zero line. I've tried doing this with "Difference (Bar)" study but have not gotten it to work. I appreciate any help on this issue. Thank you! Date Time Of Last Edit: 2020-02-03 20:28:15
[2020-02-02 11:48:17] |
Ackin - Posts: 1865 |
Try this: Study Subgraphs Subtract/Difference Study Subgraphs Subtract/Difference + change your drawstyle in the study tab settings to your desired look |
[2020-02-02 11:51:43] |
Thanks, just found the actual Study in the list & deleted request.
