Date/Time: Sat, 18 May 2024 11:37:12 +0000
Trailing Stop Without a Profit Target?
View Count: 1253
[2020-02-02 05:30:16] |
User344276 - Posts: 65 |
Is it possible to set a trailing stop without a profit target using a stop order to enter the trade? I have watched a couple YouTube windows to get the gist of how to set up orders on the Trade Window however it looks like things have changed since those videos were posted. On the YouTube videos I watched the Trade Window has an area to select Auto, and manually input the Profit, Stop loss, Distance, and Breakeven+. I don't see these options on the Trade Window with the current version of Sierra Chart. Where do I input these options now that the Trade Window has changed?
Date Time Of Last Edit: 2020-02-02 07:53:40
[2020-02-02 09:54:55] |
It sounds like you are watching a video which is not about Sierra Chart. Yes you can do what you want. You just simply do not add a Target order. Just a Trailing Stop order. Instructions: Attached Orders: Step-By-Step Instructions If there is already a Target order listed on the Targets tab of the Trade Window, simply Remove it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-02 09:55:11
