Date/Time: Sun, 27 Sep 2026 15:22:13 +0000
Questions about numbers bars chart and scrolling
View Count: 1060
[2020-02-01 18:08:57]
Nathan Davis - Posts: 2
I have the “Numbers Bars Calculated Values” on the bottom of my chart. How do I add a row that shows the volume of the bar, and a row that shows the % of the “AskV – BidV” to the bar's total volume?
Is there a way to filter the numbers bars so that they only show large orders?
I can scroll and resize the range on the price axis of the chart, but I can't scroll on the time axis. It only resizes when I move along the time.
Is there a button or key that I can push to set the chart back to the current price?
[2020-02-03 16:59:44]
John - SC Support - Posts: 48028
1) Add Volume and % Ask - Bid: Refer to the documentation here for how to add the data to the Numbers Bars Calculated Values:
2) Filter Numbers Bars: There is not filtering that is available on the Numbers Bars study itself. You would have to filter the entire chart. Refer to the information here:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
Also, note that the Numbers Bars Calculated Values can display the filtered chart values on a non-filtered chart. Refer to the information here:
Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart
3) Refer to the information here for how to scroll through the chart bars:
Working With Charts: Scrolling The Chart and Right Side Fill Space
4) Reset the horizontal axis to the current bar: Refer to the following:
Chart Menu: Goto End of Chart (Chart menu)
Also, refer to the following to reset the Price Scale:
Chart Scale and Scale Adjusting: Resetting the Scale
