Date/Time: Sat, 18 May 2024 04:37:24 +0000
Spreadsheet System multiple copies on one chart
View Count: 558
[2020-02-01 08:04:26] |
User14686603 - Posts: 14 |
Hello! Is it possible to use several Spreadsheet System on the one chart? Will there be no conflict? |
[2020-02-01 21:40:07] |
bradh - Posts: 859 |
Assuming each system is its own spreadsheet, maybe. It is possible to create systems that interfere with each other, and it is also possible to create ones that do not. You don't want to apply the same spreadsheet more than once to a chart nor have the same file active in two or more open chartbooks at the same time. |
[2020-02-02 09:19:50] |
thanks
[2020-02-03 20:32:09] |
Sierra_Chart Engineering - Posts: 14423 |
Yes as long as this Input is set differently for each instance of the Spreadsheet Study: Spreadsheet Study Inputs: Chart Data Output Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
