Date/Time: Sat, 18 May 2024 06:01:18 +0000
Only 1 chartbook opens on startup
View Count: 3616
[2020-02-01 04:56:26] |
User517455 - Posts: 3 |
Hi, I didn't see a way to open a chartbook group on startup, so in the general settings > files to open on startup, I added the 2 individual chartbooks from the chartbook group. However, when I start Sierra Chart only 1 chartbook opens. How can I get both to open? Thanks. |
[2020-02-01 10:15:58] |
There should definitely be no problems with this. All listed files to open on startup will be opened as long as the files exist. Make sure that this option is enabled: General Settings Window: Open Files On Startup (Global Settings >> General Settings >> General >> Startup) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-01 10:16:17
[2020-02-01 18:32:19] |
Yes they do exist because when I go to file > open chartbook group, everything opens. Yes that option is enabled too, but for some reason on startup they won't load. As an experiment I changed the name of 1 of the chartbooks in the group because there was a chartbook with the same name in the "data" folder, and now neither chartbook loads on startup.
[2020-02-03 20:33:58] |
Sierra_Chart Engineering - Posts: 14423 |
The only other information we can provide is that the Chartbooks being automatically opened should be located in the Data Files Folder: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) We cannot provide further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
