Date/Time: Sat, 18 May 2024 08:23:14 +0000
Chart not updating in realtime for AMD
View Count: 1180
[2020-01-31 19:44:39] |
CBR600RR - Posts: 37 |
Set up the denali data feed, the chart does not update in realtime for symbol AMD (haven't tried any other stocks). Do not see the [M].
[2020-01-31 20:06:00] |
Looks like I need the sierra feed instead of the denali feed but it won't let me enable the trial within 5 days of EOM.
[2020-01-31 20:19:26] |
Sierra_Chart Engineering - Posts: 14423 |
You will need to use the Sierra Chart Data Feed for US equities data and futures data: Real-Time Exchange Data Feeds Available From Sierra Chart Let us know if you want to start using this Data Feed and we will handle the transition for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-31 20:19:38
[2020-01-31 20:22:32] |
I guess I can wait until monday to start the trial so I don't lose 3 days.
[2020-01-31 20:26:32] |
Yes, that will be fine. But we should cancel the Denali Feed at the end of this month, today, so you will not be paying for 2 feeds next month. It will still stay active until the end of the day today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
