Date/Time: Sat, 18 May 2024 08:16:32 +0000
Can't connect to Bitmex
View Count: 576
[2020-01-31 17:35:07] |
User452630 - Posts: 12 |
Hi I can't connect to Bitmex, have reviewed some of the similar problems, mine seems different. Here is an excerpt of the log uploaded. Cheers Steve |
bitmex connection log problem.png / V - Attached On 2020-01-31 17:34:28 UTC - Size: 56.68 KB - 191 views |
[2020-02-03 09:51:14] |
We cannot resolve BitMex connection issues.
[2020-02-03 15:55:40] |
hi - I can't connect to download the historical data - is this a common problem? Do I have to download the rest of the stuff first? All the best
[2020-02-03 19:45:44] |
If you just want BitMex historical data, then do not connect directly to BitMex. Instead set Global Settings >> Data/Trade Service Settings >> Service to SC Data-All Services. Full documentation is here: Cryptocurrency / Bitcoin Data and Trading Services: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
