Date/Time: Thu, 19 Nov 2026 12:53:11 +0000
how to export market depth
View Count: 3204
| [2020-01-31 10:03:45] |
| User61576 - Posts: 458 |
I am exporting data from the chart to txt file with the indicators (numbers bars) when adding market depth historical depth indicator on the chart (depth is shown and ok) and trying to export, I am not getting on the file the depth information (other indicators info is saved) Am I doing something wrong? |
| [2020-01-31 10:23:12] |
There is no support for exporting this data but you can programmatically access it and do what you need with it. Refer to: ACSIL Interface Members - Historical Market Depth Data (c_ACSILDepthBars) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-01-31 12:18:51] |
| User311344 - Posts: 142 |
This way of accessing depth data is giving very different values than those being shown by Bid&Ask Depth bars study which is far more acurate source. Is there any possilibity to access Bid&Ask Depth bars study data via ACSIL other than referencing values of this study after it was added to the chart?
| [2020-01-31 22:10:59] |
No other way at this time.
| [2020-02-03 16:46:45] |
Any plans on making this depth data available via acsil? ETA maybe?
| [2021-09-28 08:46:25] |
| TrumpTradesOil - Posts: 12 |
FWIW This is a feature I know quite a few people would really appreciate
| [2021-09-28 09:42:45] |
| User907968 - Posts: 887 |
ACSIL Programming Concepts: Programmatically Accessing Historical and Current Market Depth Data
