Date/Time: Tue, 04 Feb 2025 16:52:40 +0000
Evening session
View Count: 603
[2020-01-30 21:12:38] |
User472677 - Posts: 362 |
Is there a setting to have evening session enabled for 1. all symbols 2. For all charts I know how to do it for individual charts and individual symbols. |
[2020-01-31 21:20:12] |
Sierra_Chart Engineering - Posts: 18246 |
You can set this through the Global Symbol Settings for symbol patterns which cover many symbols: Global Symbol Settings But it is not going to immediately change the chart setting for existing charts. It still has to be individually applied to existing charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
