Date/Time: Sat, 18 May 2024 10:41:57 +0000
Datafeed
View Count: 587
[2020-01-30 20:48:09] |
User417422 - Posts: 9 |
Hello I have a question: I have to change from CTS T 4 data unfortunately because they have no Eurex data. I have to take CQG; Rithmic or TT data feed. Which of these data feeds is best to combine with sierra chart? Thank you very much
[2020-01-31 21:16:25] |
Sierra_Chart Engineering - Posts: 14423 |
CTS does not have EUREX data? They used to. We recommend you use the following service which uses TT for the order routing: Sierra Chart / Trading Technologies Futures Order Routing Service You would then use this with the Sierra Chart Exchange Data Feed, which has the Eurex data. Refer to the following for more information: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-31 21:16:43
[2020-02-02 11:31:29] |
I am with AMP Future Broker and CTS has no EUREX there unfortunately. As I said, I have now ordered the Sierra Card TT-W datafeed. Thank you
