Date/Time: Wed, 23 Sep 2026 14:24:35 +0000
How To Add Market Depth data on Trading Dom in Trading Window
View Count: 3062
[2020-01-30 19:54:15]
Trader8188 - Posts: 20
How do I display the current bid and ask volumes by price on the trading dom on the chart?
https://imgur.com/a/S1KmAAa
imageMissing_Market_Depth.PNG / V - Attached On 2020-01-30 19:51:58 UTC - Size: 190.64 KB - 752 views
[2020-01-30 22:22:41]
John - SC Support - Posts: 47983
Right now, you have the Buy Order and Sell Order columns displayed. You would need to add the Bid Size and Ask Size columns to get the Market Depth. Or you can use the Bid Size/Buy Column and Ask Size/Sell Column instead, which combines the other two column types together.
Refer to the information starting here for the different columns:
Global Trade Settings Windows: Buy Order Column - Left/Center/Right Aligned
[2020-01-30 22:58:45]
How do I modify the font color and size for Bid Size and Ask Size columns
They appear now but are too large.
[2020-01-30 23:05:18]
Refer to the following (and the item after it) to change the color of the Depth values in the Bid and Ask columns:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Ask Depth Quantities
Refer to the following to change the font size and type (particularly the last paragraph):
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Font Settings
