Date/Time: Sat, 18 May 2024 06:22:21 +0000
Change Symbol with ACSIL
View Count: 1126
[2020-01-30 19:48:42] |
bradh - Posts: 859 |
I have a need to set the symbol of the current chart with ACSIL. I know I can set the Bar Period with ACSIL, I can read the chart symbol, but I cannot change it. Can you look at adding a function like sc.SetChartSymbol() that would complement sc.GetChartSymbol? I tried using sc.OpenChartOrGetChartReference(), and while it opens new charts, it keeps opening them if I change the symbol. This seems to be inefficient. I don't see a way to close a chart, or I might pursue this further. |
[2020-01-31 00:53:16] |
Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.DataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
