Date/Time: Sat, 18 May 2024 07:13:43 +0000
[User Discussion] - add parameters value of studies in Studies Graph box
View Count: 409
[2020-01-30 19:43:22] |
User774220 - Posts: 8 |
there are times when i have multiple indicators (different time frames, or study overlays) in my studies graph box that i want to adjust BUT i dont know which one is the 1h or 3m etc so i need to open them 1x1, very annoying (unless there is another way to tell that i am not aware of) i see some dialogue boxes have a message box with name of the indicator or value when you select it (your boxes are not able to expand), can you add the parameter values of the indicators on a hover or click of the indicator name OR can you add an additional information box below that when an indicator is selected the parameter values appear, just want an easier process to select same indicators with different setting, gets hard when there are many indicators. thanks |
