Date/Time: Sat, 18 May 2024 08:16:36 +0000
How can you have 2 instances open for 2 different trading accts & 2 different datafeeds?
View Count: 450
[2020-01-30 18:56:40] |
Jay Greenlees - Posts: 15 |
How can you have 2 instances open on the same computer for 2 different trading accounts & 2 different data feeds?
[2020-01-30 19:22:46] |
Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
