Date/Time: Tue, 04 Feb 2025 14:38:01 +0000
Sierra Chart API
View Count: 953
[2020-01-30 17:01:23]
User569373 - Posts: 27
Hello
There is a third-party application called "Sierra Charts Backtester (PssSCBT)". This application uses the back-tester functions built in in Sierra Chart.
So, there must be a Sierra Chart API they are using. The only documentation I found is about ACSIL.
Can you point me in the right direction? Thanks.
Kind Regards
User569373
[2020-01-30 17:58:40]
Sierra_Chart Engineering - Posts: 18240
We do not know how that program works. But it is not recommended that you use it.
There are new functions to access the Replay functionality within ACSIL. Refer to the following function:
sc.StartChartReplay()
There other functions related to replay as well.
