Date/Time: Sat, 18 May 2024 03:51:47 +0000
Sierra Level 5
View Count: 523
[2020-01-30 16:29:57] |
User787899 - Posts: 3 |
Hello My broker is AMP. I reset my computer and the Sierra software was deleted. I want to reinstall Sierra Level 5 software on my computer. I want to reinstall it with all my saved data that are in Sierra (chartbooks, graphs etc). How to do it? |
[2020-01-30 19:15:48] |
Sierra_Chart Engineering - Posts: 14423 |
If the Sierra Chart installation is, in fact, gone, then there is no way to recover the Chartbooks as they were previously. But, what is confusing here is why would the Sierra Chart folder be deleted from your computer just because you restarted the system. Is it just the icon that you start Sierra Chart from that is missing, and not the entire folder? By default, Sierra Chart is installed to C:\SierraChart. See if this folder still exists on your computer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
