Date/Time: Sat, 18 May 2024 07:24:52 +0000
Sierra Chart Package + Data Feed
View Count: 1033
[2020-01-30 15:10:08] |
tiphereth - Posts: 4 |
Hello, ist it possible to run a normal Sierra Charts Package + Futures Data Feed for analysing? Can you help me? Real Time? thank you! |
[2020-01-30 19:06:20] |
Sierra_Chart Engineering - Posts: 14423 |
We recommend using this is data feed which is included with the Advanced service package: Delayed Exchange Data Feed Make sure you update Sierra Chart to the current version: Software Download: Fast Update ---- Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-30 19:07:19
[2020-01-30 19:42:04] |
What should I do with „delayed Data“? I wanna trade „real time data“! Can you help me or not?
[2020-01-30 19:46:02] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-30 20:00:55] |
Ok maybe I should be more accurate. If I look for ES or NQ Data Feed for Sierra Charts what can I do? I would only use it for Simulation but like to trade real time data.
[2020-01-31 00:54:31] |
The exchange requires that you have a funded trading account as explained here: Easy Solution to CME Funded Trading Account Requirement So you need the trading account and then you will need to use this data feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-31 08:08:01] |
Ah thank you! That helps! :)
