Date/Time: Sat, 18 May 2024 07:13:42 +0000
Live Data Question
View Count: 664
[2020-01-30 14:02:06] |
User653351 - Posts: 2 |
I have a ThinkorSwim and an AMP Futures account. Can I use either of these to get live data on Sierra Charts?
[2020-01-30 20:04:47] |
Sierra_Chart Engineering - Posts: 14423 |
You cannot use TD Ameritrade (ThinkOrSwim). If you have an AMP account, we recommend you use this service which works in combination with the Sierra Chart data feeds: Sierra Chart / Trading Technologies Futures Order Routing Service Whether you want to trade with that service or not, you should still use that to authorize the CME market data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
