Date/Time: Mon, 03 Nov 2025 12:56:20 +0000
Chart Overlay (from volume chart to range chart)
View Count: 859
| [2020-01-30 12:16:29] |
| User161806 - Posts: 18 |
Hi Support Team, I'm using a bought indicator (Gomi Order FlowPro) and I'm wondering if it is possible to transpose(overlay) a specific in put from a 400 volume chart to a 3 tick range bar. the Input number is In:64 from the study which is a S/R zone. I have tried using Study/Price Overlay but it doesn't seem to work. If you have any idea's on how i can accomplish this overlay, I'd be super appreciative. Thanks for your time. Josh Date Time Of Last Edit: 2020-01-30 13:25:53
| [2020-01-30 18:10:51] |
| Sierra_Chart Engineering - Posts: 21285 |
You cannot overlay an Input from a study, just the Subgraph data. Therefore, it depends on how the creator of that study is getting that information onto the chart. If it is a Subgraph, then you should be able to take that and overlay it. Otherwise, there is not much you can do except to ask the developer to put that information into a Subgraph so you can overlay it. Refer to the information here for the Study/Price Overlay Study: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
