Date/Time: Tue, 04 Feb 2025 14:38:56 +0000
Stocks data and number bars questions
View Count: 857
[2020-01-30 11:28:17] |
BenjFlame - Posts: 335 |
Hello, Here are some question: 1) Is the STOCKS feed provided by sierra chart (I think it comes from barchart) allows to display number bars with bid/ask trades? 2) Same question for IQfeed. 3) On a number bars with bid/ask trades, what happens to trades that happen BETWEEN bid / ask spread, as is often the case on stocks? Are they ignored when accumulating the bid / ask trades on the number bar? Thanks. |
[2020-01-30 18:24:46] |
Sierra_Chart Engineering - Posts: 18240 |
1) Yes, Bid Volume and Ask Volume is supported. Therefore you can use the Numbers Bars with the data. 2) Same as above. 3) Refer to the following information for Bid Trade and Ask Trade: Numbers Bars: Definitions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
