Date/Time: Sat, 18 May 2024 08:16:35 +0000
Percent Change since Open
View Count: 438
[2020-01-30 09:24:57] |
User551971 - Posts: 34 |
Hi, i have a chartbook with which i can display the change of currencies in percent. The changes are shown either from the trading day start time or for several days when I select First Bar in the chart. What I did not find is how to display the changes of the last hours. Is there a solution for this. |
Change-Last.png / V - Attached On 2020-01-30 09:24:03 UTC - Size: 69.22 KB - 206 views change-last-study.png / V - Attached On 2020-01-30 09:24:09 UTC - Size: 17.29 KB - 182 views Attachment Deleted. |
[2020-01-30 19:24:08] |
As you have seen, those are the only options for that study. The study source code is available in the file studies8.cpp in the ACS_Source directory under the main Sierra Chart installation folder. You can modify the code for what you need. Refer to the following: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-30 19:24:28
